F
We were overhauled turbine last june. Nowadays the winter is came here.
when the gas turbine stops different causions (ex, heat recovery system failure or turbine failure). we are encountering face to t5 temperature low after running. The weather temperature mines 10. I suppose that make turbine services man set to blade valves. The cold weather is falling down t5 temperature low limit. How to run machine don't set to blade valves? thanks
<b>Moderator's Note:</b> Think causions is actually cautions. And that might be minus 10.
