Saturday, May 26, 2018
LUFP7 PROFIBUS / MODBUS Gateway module problem
I have problem with Telemecanique LUFP7 PROFIBUS / MODBUS Gateway module.
By Virajprasanna on 13 February, 2017 - 1:12 am
I'm Mechatronics engineer from Sri Lanka. I have problem with Telemecanique LUFP7 PROFIBUS / MODBUS Gateway module. Two of above modules were implemented in a Hydro Power plant (please see the communications diagram below). As the diagram LUPF7 module 2 was burnt due to power issue. I took following solutions, but nothing were success. Are there Anyone, who can help me?
(1) get a copy of LUFP7 module 1 configuration file and save it to a new LUFP7 module and apply it to second position with changed Profibus and Modbus addresses.
(2) when LUFP7 module in the position 1, change to position two we can run PLANT 2.
Moderator's Note: No diagram attached as you cannot include them in posts to the forum at this time.
You can use an image sharing site like Postimage.org and then post the "Direct link"
This is Nicole from Microcyber. We also produce Profibus/Modbus Gateway. Hope to set up relations with you, cooperation or technical discussion.
