Greetings,
The lower half of the combustion wrapper has a manhole with a pipe which drains either Water Wash or Liquid Fuel. For the Water Wash it is clear for me how the water gets into the combustion wrapper. But I don't see any way of liquid to get into the combustion wrapper. The liquid if failed to ignite will be in the combustion liner and transition piece. The lower cans will have a false start drain tubes which is on the forward casing of the Can. The liquid can't get into the combustion wrapper unless the hula seal is only air tight and not liquid tight. Any explanation please.
