On the turbine Control where the controller is Micronect Plus communicating through HMI using SOS Servilink OPC Server. On the HMI is installed Proficy HMI Scada- Cimplicity Version 8.00 build 43. It was observed that more less each 4 days the HMI loss the communication with Micronet causing Black Screen (no communication) on the Cimplicity. Looks like the OPC server stops to work may be caused by some bug...
Has someone seen such kind of issue?
