Saturday, February 24, 2018
Triad and Pair Cables
Looking for sources to buy Triad and Pair cables
By Prasad Parulekar on 31 July, 2017 - 6:14 am
I want to know the sources/manufacturer or distributors who keeps such cables in stock. We need good quantity for a running projects.
Thanks in advance for your time to guide us.
Prasad Parulekar
Prasad Parulekar,
You don't make it easy to answer your question--by not telling us what part of the world you are needing this cable. But, perhaps if you told us where the site is that requires this cabling, sometimes referred to as twisted, shielded pair cable, or three-core/conductor, twisted, shielded cable, we might be able to help. (Some parts of the world call twisted, shielded pair cable "Belden cable" because Belden makes and sells a LOT of this cable in Western parts of the world.)
Have you done a World Wide Web search of wire and cable suppliers in your region of the world? If so, what did you find?
Have you contacted any of the wire & cable suppliers in your region--and, if so, what did they say?
I have purchased many supplies, components and wire and cable from RS Components, International, and have always been happy with their service and delivery--be it in the Middle East, the UK, or Asia.
Here is a link to their multi-pair cable page:
http://export.rsdelivers.com/productlist/search?query=twisted%20shielded%20pair%20cable&Family=6599&tag=
I believe on this page they have some single pair and single triad cables--but I have gone past the first of several pages. But, the best thing is to contact your local/regional wire & cable supplier for help in finding these cables.
Hope this helps!
We are from Oman, in Gulf.
Our technical requirement is as below. WE NEED READY STOCK ONLY FOR URGENT WORK. Your guidance on probably manufacturers who can support the technical requirement with good delivery will be highly appreciated.
Sl. No. Description Qty. Unit
1 1 P X 1.50 Sq.mm THERMOKABEL MAKE CABLE :
Multi Strand Annealed Tinned Copper Conductor,
Extruded XLPE insulated, Twisted, Overall
Screened With Al Mylar Tape & 0.50 SQ.MM.
Annealed Tinned Copper Drain Wire, Extruded ZEROHALOGEN-UVPROPERTIES Outer Sheathed, Unarmoured, 300/500V Grade, Cable Generally Confirming To BS EN50288-7 1500 Mtrs
2 16 P X 1.50 Sq.mm THERMOKABEL MAKE CABLE :
Extruded XLPE insulated, Twisted, Individual
Annealed Tinned Copper Drain Wire, Such Pairs
Laid Up, Overall Screened With Al Mylar Tape &
0.50 SQ.MM. Annealed Tinned Copper Drain Wire,
Extruded ZEROHALOGEN -UV PROPERTIES Outer Sheathed, Unrmoured, 300/500 V Grade, Cable Generally Confirming To BS EN
50288-7 300 Mtrs
3 1 T X 1.50 Sq.mm THERMOKABEL MAKE CABLE :
Annealed Tinned Copper Drain Wire, Extruded ZEROHALOGEN -UVPROPERTIES Outer Sheathed, Fire Survival, Unrmoured, 300/500 V Grade, Cable Generally Confirming
To BS EN 50288-7 300 Mtrs
4 1 P X 2.50 Sq.mm THERMOKABEL MAKE CABLE :
Annealed Tinned Copper Drain Wire, Extruded ZEROHALOGEN "UVPROPERTIES Outer Sheathed, Fire Survival , Unarmoured, 300/500 V Grade, Cable Generally Confirming To BS EN 50288-7 500 Mtrs
5 1 P X 1.50 Sq.mm THERMOKABEL MAKE CABLE :
Extruded XLPE insulated, Twisted, Overall Screened With Al Mylar Tape & 0.50 SQ.MM.
Annealed Tinned Copper Drain Wire, Extruded ZEROHALOGEN "UVPROPERTIES Outer Sheathed, Fire Survival, Unarmoured, 300/500 V Grade, Cable Generally Confirming To BS EN 50288- 300 Mtrs
6 10 T X 1.50 Sq.mm THERMOKABEL MAKE CABLE :
Annealed Tinned Copper Drain Wire, Such Triads
, Extruded ZEROHALOGEN "UV PROPERTIES Outer Sheathed, Fire Survival, Unarmoured, 300/500 V Grade, Cable Generally Confirming To BS EN 50288-7 300 Mtrs
7 16 P X 1.50 Sq.mm THERMOKABEL MAKE CABLE :
Extruded ZEROHALOGEN "UV PROPERTIES Outer Sheathed, Fire Survival, Unrmoured, 300/500 V Grade, Cable Generally Confirming To BS EN 50288-7 300 Mtrs
8 16 P X 2.50 Sq.mm THERMOKABEL MAKE CABLE :
Extruded XLPE insulated, Twisted, Such Pairs
9 4 C X 10.00 Sq.mm THERMOKABEL MAKE CABLE :
Extruded XLPE insulated, SUCH CORES LAID UP,
Extruded ZEROHALOGEN -UV PROPERTIES Outer Sheathed, Unarmoured, 600/1000 V Grade, Cable Generally Confirming To AS PER BS 5467 1000 Mtrs
Notes:
1) All the cables are out door application. Hence the heat withstand and UV properties are of concern.
2) Armoured cable are acceptable in all places against unarmoured
3) All cables (Sr. No. 1 to 9) are for analogue signal transmission, hence the screening core/layer is required.
4) Sr. No. 10; 4C x 10 sq. is for Power supply unit.
5) In case, the given number of cores (dual or tri) are not available as bunch, say 16P / 10T; then the higher bunch like 20P / 12T would be preferred. Next choice would be split as 2x / Nx to meet the requirement.
