R
Can offshore ESDV riser valve with solenoid wired to ESD system? also have a separate solenoid wired to a high integrity pressure protection system? Or should the ESD and HIPPS be totally separate systems from initiating device to the in line valve. By in line valve I mean the process wetted valve.
