Calculating wake frequency for thermowell we must need, fluid velocity with other process data. But when a thermowell is to be installed at the bottom of a vessel where some fluid will enter? it will be stored there for process reason, and then transfer some other place via gravity or pump. Now in such case i don't have the flow rate/velocity of the fluid into the vessel. Note please vessel will be agitated. Now in that case how can i calculate wake frequency for the thermowell installed into the vessel? should I consider the in late /out late/flow rate of the vessel or the rpm of the agitator? Any suggestion guys?
