Tuesday, January 16, 2018
1784-PKTX Problems
Changing out 1784-PKTX to CLogix 1756-DHRIO and ENET comm setup. Help needed with comm setup.
So I made the mistake of changing my shop PC from 32 bit to 64 bit so I could install extra RAM.
After much searching and discussing with others, there are no 64bit drivers that I can find for the 1784-PKTX comm card.
Unless someone has found some, I have to do an alternate setup for talking from PC to DH+ processors.
Have RSLinx version 3.71 installed
Running RS5 Ver 7.10
Can anyone give me a link or tell me how to setup RSLinx to be able to connect to the PLC's
Thank you,
Bruce B
By Bob Peterson on 16 August, 2017 - 8:29 pm
There are no cheap answers. You could buy a control logix rack and put a DHRIO card in it and connect up to it via an Ethernet card.
I think there might be a pro soft card to interface between ethernet and data Highway Plus.
So I was able to get the DHRIO card working and can now get online with the PLC5 thru RS5 and should be able to access the SLC500 with RS500.
Only thing I have to figure out now is the DH485 communications.
I do testing for various people and need to be able to access all 3 platforms. I don't mind learning, but need to keep the last little bit of hair over my bald spot.
IF anyone knows of a working 64 bit driver for the PKTX comm card it would be appreciated.
It is a good card to have if you run multiple platforms.
Thank you
For DH+, we use one of these:
http://www.prosoft-technology.com/Products/Gateways/EtherNet-IP/EtherNet-IP-to-Allen-Bradley-Remote-I-O-or-DH-Gateway
It works great connecting to either the 3-pin phoenix connector or the round fake mini-DIN. It's also supposed to work for RIO with the right firmware update.
For DH485, we use:
https://www.plccable.com/allen-bradley-1747-uic-usb-1747-cp3-1761-cbl-pm02-1756-cp3-programming-set/
Both have been simple and reliable to use. The Prosoft gateway can also be used to connect an Ethernet/IP HMI to a PLC-5 or SLC 5/04 via DH+.
We had issues with PanelView programming (FactoryTalk View Studio) as it required a 32 bit PC. We got around that when we upgraded by installing VMware operating as a 32 bit system inside the 64 bit Windows 7. I am assuming that your hardware is still able to use the 1784-PKTX card (our new PCs won't).
A VM has its own issues but you may be able to use that as a way to use the old 32 bit driver.
Russ K
