Wednesday, June 20, 2018
Modbus TCP Settings
What are the parameters to put in ASE2000?
I am a beginner in MODBUS protocol and I am asking for anybody to help me how to set the parameter settings for ASE2000 Modbus TCP protocol.
Because we have here an Intellisaw CAM4 Reader/HMI that reads temperature from the field and this CAM4/Reader has MODBUS protocol, However, we can't get the data from CAM 4 Reader/HMI in our SCADA System using ASE2000 Communication Test Set.
What should I put in the following parameters:
Pt Adrs-
Data-
Start-
Count-
off/on-
Trans Id-
Len-
Or where can i find this parameter
Is the temperature is for Holding registers?
I am counting on your help.
Thank you in advance.
Can you provide a link to the communications manual for the CAM4/reader?
One issue might be that the spec for the ASE2000 Version 2 says that it supports "Modbus serial (RTU and ASCII)" and the tab on hardware shows USB and serial ports, not Ethernet ports. If the slave is really Modbus/TCP, then you have a hardware mismatch and will need to serial/ethernet converter.
Are you asking how to use the ASE2000?
By Modbus TCP Settings on 12 September, 2017 - 4:01 am
Hello David,
Thank you for your input and apologies for the late reply.
the ASE 2000 that i'm using supports Modbus RTU, TCP, and ASCII so I use Modbus TCP.
The slave device has an ethernet port, which we use to transfer the device configuration from pc to the device. however, when i use this ethernet port for Modbus tcp for polling the device, I cannot establish communication.
Maybe the parameters i'm using in Modbus TCP are wrong for polling temperature reading in the slave device.
if you can provide your e-mail, I will send you the device manual.
