Saturday, February 24, 2018
Barometric Pressure Transmitter Calibration
Looking for best practice for Barometric Pressure Transmitter calibration.
Historically to confirm the accuracy of the Gas Turbine barometric pressure transmitters, we installed a high accuracy Rosemount Barometric Pressure Transmitter and would just compare the readings. If the 2 Gas Turbine Barometers and the additional Rosemount Transmitter read within +/- .05 inhg of each other, we would call it good.... Now we need traceability of calibration.
Originally we planned to send out the Rosemount for NIST calibration and use that as the standard to calibrate the Gas Turbine transmitters. But since the newer Rosemount is permanently installed, we are thinking of getting a more mobile/hand held unit that is easier to send out and use that as the standard. With a known standard (as the present barometric pressure), we could then pump up and down from there. I was just wondering what others do. How do you calibrate your barometric pressure transmitters?
Could you not just compare it to a mercury manometer after all isn't that the standard, inches Hg? If you don't have a good vacuum pump tap, the manometer into the impulse tube and do it in-situ.
It should also read the barometric pressure at zero no?
I must admit I have never had to check one, just my thoughts.
