Software Troubleshooting
Maj
Hi All,
I'm new using PLC, and i have a problem with a unit using Bejer plc and IX software. The HMI shows Zeros in all parameters. The plc connection is ok, so i guess its software problem. So please any solution to fix such a problem, as i don't have access on this kind of software. Is there any other software that may be can integrate and or fix such a problem? Or do i have to buy the license of ix software?
Thank you very much and i am looking forward to hear from you
Reagrds
Maj
If you have numbers in the PLC addresses and all zeros in the HMI, it doesn't seem as though "the PLC connection is ok".
It might be as simple as the HMI has the wrong address.
What type of communications are between the two, Ethernet, serial, other?
