Wednesday, April 25, 2018
High Voltage Motor Temperature Rise
A high voltage motor temperature increased after rewinding.
Greetings to all,
A high voltage motor was sent for rewinding, and when it came back, its temperature increased by around 20 deg. It is cooled by an air-to-air heat exchanger and motor cooling fan (MCF) driven by motor shaft.
Can someone help in identifying the possible causes of temperature increase?
I assume that the heat exchanger is most probably causing the temperature rise, but how to check that?
Is it possible that the winding insulation affect motor temperature? I mean for two motors exactly the same, if we used different winding for each one, i.e. class F for one and class H for the other, would that affect the motor temperature?
Thank You in Advance
Have you asked yourself:
1. Has the heat exchanger changed in any way during rewind
2. Has the motor cooling fan changed
If neither, then it's possible the copper in the rewind is not as conductive/not creating the same magnetic field as the original.
