Thursday, May 24, 2018
Profibus DP to Modbus RTU Gateway
Need to read data from a Profibus DP to Modbus RTU gateway.
We need to read data from Profibus DP. So anyone can suggest reliable gateway to convert date from Profibus DP to Modbus RTU?
PT
PT,
what control system are you using? most of the time, you will have to bring it through the IO system, then the Controller. You could probably use a gateway in the controller or maybe up through the HMI.
Max
Hi Max,
I want to use Gateway to convert Profibus DP slave devices data into Modbus RTU. If any good gateway you know, please suggest.
PT
Hi PT,
there are many gateway products to choose from. look at prosoft technology, hilscher, rta automation, hms anybus. good luck.
GAK
By Ikhtiander - on 15 May, 2018 - 8:30 am
Hi ptewari,
For Modbus Serial Master to Profibus DP slave you can use Prosoft 5105-MCM-PDPS:
http://www.prosoft-technology.com/Products/Gateways/Modbus-Master-Slave/Modbus-Master-Slave-to-PROFIBUS-DP-Slave-Gateway
If you need Profibus DP Master to Modbus Serial slave you can use 5104-MCM-PDPMV1:
https://www.prosoft-technology.com/Products/Gateways/Modbus-Master-Slave/Modbus-Master-Slave-to-PROFIBUS-DPV1-Master-Gateway
Thanks and best regards,
Ikhtiander
Thanks all for their suggestion.
PT
By Bob Peterson on 15 May, 2018 - 8:52 pm
Realtimeautomation.com
Bob
