Hello, in response to lib/TODO item 40, I've written a new function for the gmm that returns various sundry details about a point. As it says in the comment, it's not intended for general consumption but rather for those who for one reason or another need to know the guts of the gmm (``bypass the abstraction'', to use the technical term). The function is called plc_pt_details() and currently lets you find out the validity of a point, its offset and bit address, length and r/w status. This may be expanded at need. Comments? Jiri -- Jiri Baum <[email protected]> Connect the power cable, interface cable and ground wire only in the methods indicated in the this manual. It may lead to fire. -- OKIPAGE 8z user's manual _______________________________________________ LinuxPLC mailing list [email protected] http://linuxplc.org/mailman/listinfo/linuxplc
