Hi list,
I'm trying to find a flowmeter that will accurately measure very low flow rates
(around 0.0023 GPM [US Gallons]) and display the rate on a small LCD display.
The meter should also have a 4-20mA or 0-10V output proportional to rate. I would prefer to power it with an external 115VAC source, rather than loop-power. Ideally, the meter would have a calibrated display which would allow me to scale the flow rate into different units (e.g. convert
from GPM to lb/min).
The liquid is carried in a 1/4" nylon tube, so a meter that would allow me to install press-in fittings for quick connection would be desirable.
If anyone has used such a meter, I would appreciate any information you could give me regarding manufacturers.
Dean
_________________
Dean Reimer
Process/Project Engineer
BPB Westroc Inc=2E
Ph: 604-527-1421
Cel: 604-617-0070
Fax: 604-525-0468
Dean
_________________
Dean Reimer
BPB Westroc Inc=2E
Ph: 604-527-1421
Cel: 604-617-0070
Fax: 604-525-0468
