Hi All
I am looking for 2 different devices and wonder if anyone has any product recommendations they would like to make to assist.
1) Looking for an RJ45/FO rail mount converter for glass fibre, industrial standard with external power supply with 100Meg capability.
2) Looking for an Ethernet hub with minimum 3 ports RJ45 and stacking connection using glass FO port. Stacking normally implies little other than
a cross over connection so I would presume any FO port would work as the crossing over is done by swapping the 2 FO cores????
Donald Pittendrigh
Donald Pittendrigh
