I'm trying (with little luck) to write a linux RS485 driver for a
RS232/RS485 converter and a single RS485 bus device. I'm not sure what is
happening but we cannot seem to get the RS485 bus to listen or talk.
Not sure if you or one of your contacts could help us.
The information supplied to us regarding the RS485 bus is as follows:
COMM Protocol
The aim of the protocol is to provide an easily decipherable massaging
system which supports both SSCII and Binary Data Exchange between nodes in
the equipment.
Bus Communications
Communications between needs is implemented on a half duplex RS-485 serial
bus. One node is initially designated as master (typically the
Controller).
All other nodes are slave nodes and may only communicate in response to
messages addressed to them. Control may be passed from the master to any
slave by issuing an "Escape" Command back to the master.
Most messages will contain ASCII only and thus may be easily interpreted
on
a dumb terminal.
Message Format
<DLE ; Data Link Escape Char = "!"
<RID ; Receiver ID = "A" - "Z"
<TID ; Sender ID = "A" - "Z"
<MSG ; Message Data
<EOM ; End of Message = Carriage Return = 13
<DLE in Message Data is replaced by <DLE<DLE
<EOM in Message Data is replaced by <DLE<EOM
Message Data
Message Data may be a command or a response to a command.
Command Codes are:
# - Number of Parameters
D - Decrement Parameter or set to Off
E - Escape, ie: pass control
I - Increment Parameter or set to On
S - Set Parameter
N - Name of Device
P - Name of Parameter
V - Value of Parameter
Sample C Code attached
COMM Protocol
the equipment.
Bus Communications
Controller).
on
a dumb terminal.
Message Format
<MSG ; Message Data
Message Data
Command Codes are:
S - Set Parameter
N - Name of Device
