member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Barth's Distinction:
There are two types of people: those who divide people into two
types, and those who don't.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
1 2 3 4 5 6 7 8 9 10 11 Next
Control.com topic...
Open Control
from the Forum department...
10mA output question
Topic: Continuous process industries, DCS questions.
Originally posted by Hattersuk on 19 November, 2009 - 7:10 am
provide input to a Data Acquisition Unit (DA100) requires 5VDC input with 10mA transistor output
New Replies:
You are not doing any better at describing what you want. You say that the 10ma. output needs to...
Thank you. I don't think i have described this very well. I need to use a 10mA output that i...
Ohms law says current through a resistor creates a voltage drop. R = E/I R = 5V/0.010A R = 500...
from the Automation Applications department...
Rotart Shear cutter into Metal sheet cutting
Topic: Application Questions and Problems
Originally posted by Edwin on 16 November, 2009 - 3:03 am
Machine which we are going to do with Rotart shear cutter for cutting metal sheets from 800 mm to 5000 mm
New Replies:
I agree that the rotary cutter should not have to stop between cuts. With a decent controller you...
your customer is correct you should be able to develop a profile for constant motion... you...
from the CAN I do it? department...
CANOpen
Topic: Open interfaces, software and hardware
Originally posted by Bill Code on 31 August, 2009 - 6:25 pm
CANOpen technologies
New Replies:
Have a look at http://www.canopen.nu. ...
>HBC-radiomatic has a wide range of radio remote controls with CANOpen interface. ...
Beckhoff has wide range products for many popular field buses including of course CANopen one. ...
By Heinz-Jürgen Oertel on 3 September, 2009 - 9:54 am -
> I would assume that drivers normally come with the interface boards. < Besides some...
Another source is : http://www.can-wiki.info at least for boards and drivers and higher layer...
The web site for the trade group is: "http://www.can-cia.org/". They have a product guide...
from the PID_ISA blocks with Cimplicity? department...
Proficy machine edition
Topic: Software, including programming, OS issues, etc.
Originally posted by Mike on 18 October, 2009 - 12:33 am
Is there a way to call or set variables in the PID_ISA block from cimplicity like the Integral or Proportion ?
New Replies:
Yes, you can access the registers of the PID_ISA from CIMPLICITY to tune the block. You'll need to...
PLC Recomendations
Topic: PLCs and related questions.
Originally posted by Mike Williams on 23 March, 2009 - 4:31 pm
Need a PLC that runs on 12 volts and supports IEC 1131-3 Structured Text.
New Replies:
Beckhoff has a large range of controllers that use their Twincat IEC 6-1131 software, allow you to...
Originally posted by krk on 18 September, 2009 - 1:41 pm
Using matricon opc datamanager, trying to establish a bidirectional communication with Honeywell APP node OPC server & Siemens simatic S7 OPC server.
New Replies:
Have you got a data historian system that can read the data in to first using a true OPC Client ?...
If you need a hand, your best bet will be to contact MatrikonOPC's support at www.OPCSupport.com ...
from the application, engineering, automation department...
Interfacing Siemens S7-300 cpu 313C with ABB's compact HMI scada
Posted by gowrishankar on 23 September, 2009 - 5:25 am
How to interface the Siemens S7-300 cpu 313C with ABB's Compact HMI SCADA?
from the What are users using? department...
Technologies being accepted
Topic: Engineering and workplace issues.
Originally posted by Tom Bullock on 22 September, 2009 - 11:26 am
Some technologies have been in development for years, but only a few enjoy commercial success.
New Replies:
If I knew the answer to all that for sure, then in 3 to 5 years I would probably be pretty rich. I...
from the Vendors coin the phrase proprietary open department...
How important is multivendor interoperability to you?
Topic: The Business of Automation and Control
Originally posted by Thomas J. Burke on 16 September, 2009 - 9:13 am
Industry open standards versus vendor proprietary open. As the President of the OPC Foundation I'm trying to assess the importance of secure reliable interoperability, and the value proposition of interoperability from the end-user perspective.
New Replies:
In reply to Ken Crater: The original OMAC documents from 10 years ago are still on their web...
Jeremy mentioned... >Ken Crater tried this with an independent lab and there was no interest...
In reply to Dan Muller: You said "Remember that Compuserve et al used closed standards in an...
M Griffin's example is correct, of course, but the question is how does his analogy apply to the...
What's wrong with simply having open protocols? I don't have anything against the OPC Foundation,...
from the POWER department...
GT trip during Fuel Change Over
Topic: Power generation equipment control.
Posted by s das on 18 September, 2009 - 3:36 pm
from the Open control in automation department...
MBLogic Free Soft Logic - Release
Originally posted by M Griffin on 23 February, 2009 - 1:53 am
Free/Open Source software project MBLogic now has soft logic.
New Replies:
Don't forget with the EZAutomation I/O that you also have to include a base. The base contains all...
Thanks for the pointers. EZAutomation does provide good prized and flexible I/O (ModBus RTU; ModBus...
Thanks for the reply. I was thinking maybe I can use a ModBus to I2C converter. Googling for such a...
Try EZAutomation for low cost Modbus I/O.   Bill Sturm ...
I haven't implemented any drivers for I2C or X10, as I don't have any suitable hardware to test...
Can the MBLogic software be adapted to also work with I2C (I²C) and X10? I would use it then to...
TDC 3000 Honeywell
Originally posted by Mozhgan Abootorab on 5 August, 2009 - 1:39 am
Our TDC3000 system needs to a high voltage transformer.
New Replies:
Like Western Process Computers, VartechSystems also sells LCD touchscreen replacements for Aydin...
Second hand parts can be bought from: http://www.westernprocess.com/index.asp...
Originally posted by Mukesh. Laddha on 14 September, 2009 - 7:13 am
What is the difference between Self regulating pressure control valves and filter regulator?
New Replies:
Self regulating control valves are valves that regulates the pressure of a line constant by either...
from the Which HMI do you simply hate? department...
TOP 10 list of WORST HMI & SCADA
Topic: Human-Machine Interface and SCADA.
Originally posted by Luciano Dell'Orfano - RTS Argentina on 12 October, 2002 - 9:35 am
I know everyone has their personal preferences, but I think it would be more interesting to discover which software is the worst...
New Replies:
I have over 8 years experience with PARAGON. I am specialized in Fermentation and Bioreactor...
IS Barriers for analog inputs
Originally posted by NG on 18 August, 2009 - 6:27 am
I want to procure IS passive barriers for analog inputs like pressure, temp and flow transmitters. Flow transmitters are basically vortex type transmitters with local display cum tantalizer in a separate enclosure.
New Replies:
Better go with MTL 40** series. I used it....
Omron Host Link driver in Java
Originally posted by Anonymous on 13 November, 2005 - 3:30 pm
is anybody is interested in an Omron Host Link driver written in Java
New Replies:
Hello, I am working on a project to convert from vb to java using this omron. It would be a...
Modbus frame size
Topic: Communications systems and equipment.
Originally posted by Bin on 6 August, 2009 - 5:25 am
Can I use the Modbus frame size larger than 256 bytes?
New Replies:
The answer is NO The volume and speed of data you wish to exchange between both the client and...
It's hard to suggest a good alternate protocol without knowing a lot about the application. So far,...
Hi, Since you are controlling both ends it might be advantageous to create your own. FTP...
Thanks very much for your reply. In my case, I am in control of both ends. I need to transfer...
Originally posted by NMD on 4 September, 2007 - 6:13 pm
I want to know about the mathematical model or transfer function of elements such as: Needle Valve, Differential Pressure Transmitter, Control Valve, etc.
New Replies:
moderators note: This request is similar to one made a few years ago. It is not...
Advertisement
