member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
"If you don't want your dog to have bad breath, do what I do: Pour a little
Lavoris in the toilet."
-- Jay Leno
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
1 2 3 4 5 6 7 8 9 10 11 Next
Control.com topic...
HMI
from the Forum department...
HMI and MMI
Topic: Human-Machine Interface and SCADA.
Originally posted by Node17 on 20 November, 2009 - 5:16 am
what is the difference between MMI and HMI?
New Replies:
Mamal Machine Interface who could you offend by that?...
Hi, nothing apart from you get sued for being sexiest if sell mmi's. lol...
from the Instrumentation department...
DeltaV I/O Card problem
Topic: Software, including programming, OS issues, etc.
Originally posted by Ghate Vinod on 3 November, 2009 - 1:58 am
DeltaV AO Card Malfunction.
New Replies:
Dear Brian; Actually we didn't download the card. we are using Meco multimeters (very simle...
Hi Ghate, What type of instrument/multimeter did you use to measure the voltage. Did you measure...
Missing Diagnostic Alarm
Originally posted by Wu on 17 November, 2009 - 11:51 am
Missing Diagnostic alarm from MKV Panel
New Replies:
Yes there is more than one unit being installed. The other one has the same prom set, but as the...
So, there is more than one unit being installed? If so, what are the PROM revision numbers for...
At the moment they are quite in the dark also. I hope that before the end of the other...
If you're commissioning a new unit with a Mark V, what does GE say? ...
I tried verifying all this things. the only thing that comes to mind is the same that I've got at...
Then it would seem there is something amiss with the installation of TCI, CIMBRIDGE, or CIMPLICITY....
Yes sorry for not mentioning it. but I've already checked the Cimplicity alarm screen setup and it...
Now here's an interesting post. Someone who's concerned about the lack of...
from the E&I department...
MARKV HMI
Topic: Engineering and workplace issues.
Originally posted by NEWENTRY on 10 June, 2009 - 6:05 am
GT Upgrade of control system
New Replies:
In reply to your posting, CSE Engineering offers our Windows based, IBECS for Turbine Control...
Originally posted by mayday_malone on 15 November, 2009 - 1:01 pm
How to determine update rate of GES driver to talk to RX3i.
New Replies:
The update rate depends on your OPC Server options but for sure it will never have better...
Please contact FieldServer at 408.964.4446 for the OPCFieldServer solution. The FS-B-OPC Server...
have you tried contacting OPC Support? Please feel free to contact us at: 1-877-OPC-4ALL you can...
from the GE energy (mark V) department...
ISA arcnet documentation
Originally posted by marco on 18 October, 2009 - 9:29 am
Doc to configure the jumper of the hmi arcnet isa card
New Replies:
Here is a link to the SOHARD ISA ArcNet manual: ...
from the PSEB department...
TDC 3000
Originally posted by singhbvirk on 21 September, 2009 - 5:55 am
How to print tag nos. and descriptions of historised points in TDC 3000
New Replies:
To find out parameter names (specifically for UCN nodes/UCN node specific conf/tags built on NIM)...
Topic: Communications systems and equipment.
Originally posted by Daniel Barrera on 13 November, 2009 - 9:26 am
I have a problem when I want to read the modbus of SHARK 100, because I can't read 32-bit IEEE floating point format in VIJEO DESIGNER 5.0.
New Replies:
Hi guys, If you cannot find a solution, I can recommend using a gateway. HMS has one that may...
> And, speaking of standards... I would sure love to see a date standard. What is 3/6/9? March...
There is an option for each device communications driver to change the double word order. If the FP...
from the Automation department...
Genesis32 SCADA and Unitronics OPC Server
Topic: Computers in manufacturing; also hardware discussion.
Originally posted by Paul Cruz on 16 November, 2009 - 12:26 am
need help with Gen32 to be used with Unitronics UniOPC Server
New Replies:
Hi Paul, I have used Genesis32 with Unitronics PLC's before. The Unitronics OPC server does not...
Tracking in Process Control
Originally posted by sonicjoe_xx on 15 November, 2009 - 12:02 am
setpoint tracking, manual tracking , control output tracking
New Replies:
Hi, setpoint tracking is enabling a bumpless transfer when the controller is switched from...
Originally posted by Thomas on 29 October, 2009 - 12:05 pm
In the TMR MKV panel with HMI in windows2000 operating system the diagnostic counters when opened is showing only two cores i.e. <C> and <R> but not the other two processors <S> and <T>.
New Replies:
CSA, Thanks for the reply, before to try correcting the errors in the above files I would like...
Thomas, You are the victim of poor configuration from the GE factory, and a poor start-up. ...
from the Stop the Post, I want to get off! department...
Panelview Self-test Loop
Posted by Patrick on 13 November, 2009 - 10:01 am
Does anyone know how to stop the posts (AB talk for the start-up self-test loo)???
Wonderware HMI conversion
Originally posted by Zahid Ali Khan on 11 November, 2009 - 1:43 am
wonderware conversion from v5.0 t0 v7.1
New Replies:
and V7.1 on Win NT or Win 2000 does not require an old computer???...
because V5.0 run on win3.1 and win3.1 need old computer. How we recompiling in 32 bit version of v?...
You have a 16 bit VB app DOSRelay.exe as part of your application. This will need recompiling in a...
from the designer department...
HMI Softwares
Originally posted by parviz parvizi on 16 July, 2003 - 10:52 am
Is it better to write our own HMI by delphi and HMI components or use commercial available HMI softwares?
New Replies:
Basic summary of stuff that I have learnt is this: - The programmer in me loves doing things my...
KingFisher To WW I/O server
Originally posted by Herman on 15 September, 2009 - 7:43 pm
Connecting KingFisher to Wonderware
New Replies:
dear Herman, there is a software called Parasyn (Australian company) who have a driver which...
MarkV servo calibration
Originally posted by iqbal on 9 November, 2009 - 7:18 am
MarkV srv calibration
New Replies:
CSA, You are right. The SRV must be passing. SRV and GCV are integrated one assembly. Ours is...
Please tell us what type of GE-design heavy duty gas turbine you are working on, and whether or not...
from the OIU department...
Bailey net90 OIU troubles
Topic: Continuous process industries, DCS questions.
Originally posted by George on 6 November, 2009 - 12:24 pm
Two OIU's crashed at our facility and no matter what parts I throw at them, they won't come back.
New Replies:
Ok I changed out the back plane with one we had in spares. No Luck. Same result. The part I used...
Wow!! surprised that some old OIU's are still out there doing their jobs... I agree, check the...
Oh memories, memories, the first Bailey OIU and the best HMI they ever made.. Diagnostics, chunky...
from the control department...
toolbox graphic project
Originally posted by any one on 9 November, 2009 - 12:47 am
I want to make graphic window in toolbox instead of cimplicity HMI
New Replies:
Graphics Windows are a separate stand-alone file (.grw) that you create simply with File->New...
Have you tried to create a Graphics Window? Have you read the Toolbox Help file on the...
MARK VI Problem with TCI
Originally posted by ahmed ali on 1 November, 2009 - 4:58 am
I have some problems on the TCI.
it stops when the operating system of the HMI start.
New Replies:
Dear Mr. CSA can you send me your e-mail so we can talk without any delays and I will do...
Ahmed Ali, I really don't understand the problem. I saw your 'photo album' and I've re-read your...
CSA please can you check my problem again.....
Advertisement
