member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
When I said "we", officer, I was referring to myself, the four young
ladies, and, of course, the goat.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
1 2 3 4 5 6 7 8 9 10 11 Next
Control.com topic...
PCs in Automation
from the Forum department...
10mA output question
Topic: Continuous process industries, DCS questions.
Originally posted by Hattersuk on 19 November, 2009 - 7:10 am
provide input to a Data Acquisition Unit (DA100) requires 5VDC input with 10mA transistor output
New Replies:
You are not doing any better at describing what you want. You say that the 10ma. output needs to...
Thank you. I don't think i have described this very well. I need to use a 10mA output that i...
Ohms law says current through a resistor creates a voltage drop. R = E/I R = 5V/0.010A R = 500...
from the Try-out? department...
Honeywell Experion PKS demo available?
Topic: Software, including programming, OS issues, etc.
Originally posted by V4 on 30 October, 2009 - 5:38 am
Any demo-software available?
New Replies:
I know Honeywell sells a development system software license for Experion with C200 or C300...
Sorry for going lil off topic. SPR, are you experienced with Honey Plantscape R500 as well? ...
Based on your comments above I detect that you are a local EPC. I would recommend that you work...
Experion PKS is a bundled package with C300/C200 hardware. You cannot have a convincing demo with...
Wind turbine control system
Topic: Power generation equipment control.
Posted by Brian Mullen on 19 November, 2009 - 11:15 am
What do you use PLC or DCS to control wind turbines?
Modbus and acyclic time
Topic: PLCs and related questions.
New Replies:
Some of the functionalities are located on the field, in particular the diagnostic functions. I...
Modbus is strictly a communications protocol. The DCS, PLC, or other controller determines how and...
from the Automation department...
Genesis32 SCADA and Unitronics OPC Server
Topic: Computers in manufacturing; also hardware discussion.
Originally posted by Paul Cruz on 16 November, 2009 - 12:26 am
need help with Gen32 to be used with Unitronics UniOPC Server
New Replies:
Hi Paul, I have used Genesis32 with Unitronics PLC's before. The Unitronics OPC server does not...
from the Help please! department...
S7-200 Wonderware Incontrol via USB PPI cable
Posted by Kevin on 16 November, 2009 - 7:35 am
I need to program s7-200 using USB PPI cable and wonderware incontrol
Originally posted by Simon Hedges on 18 August, 2009 - 5:45 am
I want to be able to transfer system configuration data from the Beckhoff TwinCAT System Manager .tsm file to a drawing package (terminal type, channel names, connections, comments).
New Replies:
You'll find some answers to this question in the discussions at the TwinCAT Developers group on...
A more modern and useful method is to use .xml (under Actions heading). TwinCAT System Manager is...
try selecting the fieldbus (Device) in the tree view on the left side of tsm. enable 'Show Sub...
from the Communication issue department...
Connecting Zelio Smart Relay with Kepware OPC Server
Originally posted by Waleed El-Badry on 30 October, 2009 - 10:47 am
I'd like to pull data from the Telemecanique Zelio Logic Relay.
New Replies:
I really would like to thanks all of you for dedicating time to answer my post. I only want to...
If you want to use modbus you must buy a modbus expansion unit to plug on the side of the zelio...
If you need a Modbus and OPCServer converter, check out the FieldServer OPCServer from...
I would be surprised if you find a freeware server that will do the job. If the one you have is not...
Thanks Wassim for your response, I regret to inform you that the link you posted is reported as...
Try this OPC Server... and let me know how it goes ...
from the automated guided vehicle department...
Posted by any on 8 November, 2009 - 12:21 pm
how to control speed in servo motor
Beckhoff TwinCAT TCP/IP sockets?
Topic: Communications systems and equipment.
Originally posted by arg on 9 October, 2009 - 4:34 pm
Does TwinCAT have Function Blocks for TCP/IP?
New Replies:
yes. Direct access to TCP/IP Stack is available for TwinCAT. It's called the "TwinCAT...
Posted by smallsnowball on 2 November, 2009 - 9:39 pm
Whenever I start Simatic Manager, a message windows "server busy" always pop out.
from the Spurious diagnostic alarms department...
Spurious MKV Diagnostic alarms
Topic: Engineering and workplace issues.
Posted by Brian on 2 November, 2009 - 9:29 pm
Spurious diagnostic alarms from MKV panel
DC Drive tuning
Originally posted by Edwin on 2 November, 2009 - 12:41 am
need to scale down the voltage in to 0 - 9 for running the motor in safe side
New Replies:
The normal method of doing this is to use a signal conditioner module with a DC input and a DC...
Limit To Onscreen Controls - Intouch
Topic: Human-Machine Interface and SCADA.
Posted by hein123 on 29 October, 2009 - 4:54 pm
Is there a limit to how many onscreen controls Intouch 9.5 can have?
Posted by multi screen on 29 October, 2009 - 1:09 pm
Want to replace my DR Seufert MXT Graphics Server with a Linux PC
from the Sensors & actuators, PLC systems department...
Automated Control of Manufacturing Systems
Posted by Norbert Edomah on 26 October, 2009 - 11:03 am
I need ideas for my project on Automated Control of Manufacturing Systems
Originally posted by Kunal S Dabi on 24 October, 2009 - 8:16 am
What is the advantage of using duplex type RTDs in HV Motor protection
New Replies:
Kunal... typically, RTD's used to monitor motor temperature are embedded in the winding slot. Thus,...
Without knowing the application of High Voltage motor protection, let me state some basics of...
from the Controlling 220 volt motor department...
controlling a 220 volts from S5 100 U
Posted by Bahaa on 19 October, 2009 - 10:35 am
controlling a 220v motor from siemens s5 100 u plc
Originally posted by M Griffin on 11 October, 2009 - 11:18 pm
A computer virus caused serious problems recently for an Australian electric utility.
New Replies:
In reply to Matt Warshawsky: I don't want to flog this issue to death, but there are a couple of...
It was never my intention to simply pass the same traffic over serial, but instead to use a simple...
In reply to Matt Warshawsky: I don't think we need to go to the lengths of installing serial...
Michael, I think that I am more or less in agreement with your sentiment. The problem I have is...
By Andrey Romanenko on 15 October, 2009 - 8:08 am -
>OK, here is an idea to solve the problem: instead of connecting the business network and the...
Yes, you are correct on everything you said. In my opinion, the reason there are so many security...
In reply to DaveMH: You said: "Ultimately the responsibility for security lies with those on...
from the Instrumentation department...
Modbus on TCP
Originally posted by Francisco on 15 October, 2009 - 7:32 am
Is it possible to use any RS232 to TCP converter or should I use a specific converter for Modbus?
New Replies:
I use a B&B ESP901 Single Port RS-232/422/485, as an example, and it can be used with any...
Modbus over TCP is what you get when you use a straing serial to ethernet converter. This is...
Advertisement
