member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Forgetfulness, n.:
A gift of God bestowed upon debtors in compensation for their
destitution of conscience.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
1 2 3 4 5 6 7 8 9 10 11 Next
Control.com topic...
PLCs
Calculating flow from analog input
Topic: PLCs and related questions.
Originally posted by outacontrolman on 19 November, 2009 - 2:23 pm
need help making the logic to perform the calculations to exchange 4-20mA into a pulse output
New Replies:
"I am using a flow meter to measure the GPM and that sends a pulse signal to a converter that...
Topic: Local and wide area networking in factory automation.
Posted by Jose Claudeni on 20 November, 2009 - 1:25 pm
Can MODBUS TCP/IP devices share the same infrastructure with Ethernet/IP devices?
from the Operation department...
Modbus analyzer
Topic: Communications systems and equipment.
Originally posted by James on 20 November, 2009 - 5:53 am
Searching some Modbus sniffer software. freeware if available.
New Replies:
I have a free WIN32 Console application that diode auctioneers two Async data streams into one...
from the astronomical instrumentation department...
C code on a PLC
Originally posted by Wim on 18 November, 2009 - 4:12 am
We are re-implementing the motion control of an astronomical telescope, and need to include complex calculations (in C code) into the position loop.
New Replies:
> [clip] > 3) on a PC: i.e. implement everything with a PC and linux compatible hardware....
> ==> Automation List post by M Griffin... > [ clip ] > I don't want to give the...
Sounds like a switch to a better supported card would get you going and preserve the work you've...
Thank you very much for spending your time and efforts... your views are most interesting, and very...
For each axis you will have a servo motor and drive. The motor will have its own encoder which will...
Hi, Thank you very much for all the answers. It is true that telescopes are mainly controlled...
The first thing I would do would be to ask the other observatories how they are running this...
> Bill Sturm, Once again, it's much easier to do PLC functions on a < I don't know how...
Depending on the time involved and the performance requirements with regards to positioning,...
Hello Wim: Our controllers have been used for many years now on many of the large telescopes...
Moderator's Note: post corrected to remove name at beginning of post. Once...
This sounds like a good application for a Delta Tau PMAC controller. The processing speed and...
Hello, We have customers which are using PLCs from Siemens together with QNX PCs for running...
Some of your details are a bit vague, but it sounds like you want to skip the PLC and go with a...
from the EMB department...
Modbus addressing for Function code 01
Topic: Power generation equipment control.
Posted by shailendra singh on 20 November, 2009 - 3:18 am
using function code 01 for reading Booleans and from slave side address given 40010 what will our starting address?
from the Forum department...
Missing Diagnostic Alarm
Topic: Human-Machine Interface and SCADA.
Originally posted by Wu on 17 November, 2009 - 11:51 am
Missing Diagnostic alarm from MKV Panel
New Replies:
Yes there is more than one unit being installed. The other one has the same prom set, but as the...
So, there is more than one unit being installed? If so, what are the PROM revision numbers for...
At the moment they are quite in the dark also. I hope that before the end of the other...
If you're commissioning a new unit with a Mark V, what does GE say? ...
I tried verifying all this things. the only thing that comes to mind is the same that I've got at...
Then it would seem there is something amiss with the installation of TCI, CIMBRIDGE, or CIMPLICITY....
Yes sorry for not mentioning it. but I've already checked the Cimplicity alarm screen setup and it...
Now here's an interesting post. Someone who's concerned about the lack of...
from the yep department...
altivar71/ioscan
Originally posted by jagg on 17 November, 2009 - 10:12 pm
Would like to setup a alt71 to comm. with our plc quantum with a noe77111 card.
New Replies:
Hi, yes it is modicon cpu, with unity software. After a bit more reading i am able to send...
What type of device are you going to use to control the Altivar 71 Drive? If it is a Modicon PLC,...
Wind turbine control system
Posted by Brian Mullen on 19 November, 2009 - 11:15 am
What do you use PLC or DCS to control wind turbines?
Topic: Sensor technologies.
Posted by Node17 on 18 November, 2009 - 7:15 pm
frequent trouble alarm in Det-Tronics system with Eagle Quantum Premier controller and LON network
Originally posted by mayday_malone on 15 November, 2009 - 1:01 pm
How to determine update rate of GES driver to talk to RX3i.
New Replies:
The update rate depends on your OPC Server options but for sure it will never have better...
Please contact FieldServer at 408.964.4446 for the OPCFieldServer solution. The FS-B-OPC Server...
from the Automation Applications department...
Rotart Shear cutter into Metal sheet cutting
Topic: Application Questions and Problems
Originally posted by Edwin on 16 November, 2009 - 3:03 am
Machine which we are going to do with Rotart shear cutter for cutting metal sheets from 800 mm to 5000 mm
New Replies:
I agree that the rotary cutter should not have to stop between cuts. With a decent controller you...
your customer is correct you should be able to develop a profile for constant motion... you...
Micrologix 1100 to Agilent 34980A
Originally posted by sfras on 29 October, 2009 - 8:50 am
Need to connect Micrologix 1100 PLC to Agilent 34980A.
New Replies:
Am I missing something? What does the IEEE 488.1 and 488.2 standard have to do with RS485? The MM...
I am not sure if the Micrologix can do ASCII serial, but if it can then you should be able to use...
Originally posted by interop on 3 February, 2009 - 12:04 pm
Can only read 6 registers from Controlotron 1010 flow meter via Modbus
New Replies:
If you are using a Prosoft Module for Modbus Communication from a PLC and you are getting a Command...
from the PSEB department...
TDC 3000
Originally posted by singhbvirk on 21 September, 2009 - 5:55 am
How to print tag nos. and descriptions of historised points in TDC 3000
New Replies:
To find out parameter names (specifically for UCN nodes/UCN node specific conf/tags built on NIM)...
from the instrumentation & control department...
DCS How to check the scan time of DCS
Originally posted by Gaurav Kale on 16 November, 2009 - 2:03 am
How to check scan time of DCS & PLC
New Replies:
For other questions: 3. CONTROLLER LOADING: PLC controller loading is with respect to your...
SCAN period in PLC and DCS are fundamentally different. PLC: it is the time taken to scan &...
Modbus and acyclic time
New Replies:
Some of the functionalities are located on the field, in particular the diagnostic functions. I...
Modbus is strictly a communications protocol. The DCS, PLC, or other controller determines how and...
from the crane electrical department...
atv 71used to control hoist motor of crae
Originally posted by mark villanueva on 16 November, 2009 - 2:01 pm
Hoist motor vibrates while drive and motor is taking high current and it vibrates though brake was open but motor is not running
New Replies:
It sounds like single phasing, check each phase with a clip on ammeter. If it's not that could be...
from the Automation department...
Genesis32 SCADA and Unitronics OPC Server
Topic: Computers in manufacturing; also hardware discussion.
Originally posted by Paul Cruz on 16 November, 2009 - 12:26 am
need help with Gen32 to be used with Unitronics UniOPC Server
New Replies:
Hi Paul, I have used Genesis32 with Unitronics PLC's before. The Unitronics OPC server does not...
advertisements
Find the right Modbus device for your project... or list your Modbus device on the largest online Modbus device directory.
