member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Authors (and perhaps columnists) eventually rise to the top of whatever
depths they were once able to plumb.
-- Stanley Kaufman
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
1 2 3 4 5 6 7 8 9 10 11 Next
Control.com topic...
Power Generation
from the Forum department...
Upgrading from Mark-4
Topic: Power generation equipment control.
Posted by Devil_machine on 20 November, 2009 - 1:13 pm
upgrade of mark-4 control system to a newer version of control system.
pole of a generator
Posted by ask on 20 November, 2009 - 10:19 am
what is the physical significance of "Pole" of the generator?
from the ELECTRICAL SERVICES department...
WAUKESHA GAS ENGINES
Posted by ARSHAD on 20 November, 2009 - 9:56 am
i want to discuss GAS ENGINES BACK FIRE , DETONATIONS , IGNITION TIMING, CYLINDER TEMPERATURE PROBLEMS
PI System in Power Plants
Posted by Ranjeet Vaishnav on 20 November, 2009 - 3:26 am
looking to connect with people who have used the PI System in Power
Plants
from the EMB department...
Modbus addressing for Function code 01
Posted by shailendra singh on 20 November, 2009 - 3:18 am
using function code 01 for reading Booleans and from slave side address given 40010 what will our starting address?
from the E&I department...
MARKV HMI
Topic: Engineering and workplace issues.
Originally posted by NEWENTRY on 10 June, 2009 - 6:05 am
GT Upgrade of control system
New Replies:
In reply to your posting, CSE Engineering offers our Windows based, IBECS for Turbine Control...
from the monitoring department...
AutoTuning on 7EA
Topic: Sensor technologies.
Posted by car1615 on 19 November, 2009 - 2:00 pm
Does anyone have experience with AutoTuning on 7EA w/ DLN1?
Wind turbine control system
Posted by Brian Mullen on 19 November, 2009 - 11:15 am
What do you use PLC or DCS to control wind turbines?
Pneumatic valve positioner
Originally posted by Micik on 14 November, 2009 - 3:45 am
Control valve positioner and its characteristic
New Replies:
The characteristic of the positioner should be set to match the physical response of the valve that...
Hi, the experience has shown that it is not necessary to conduct a comprehensive study to...
Well, I was thinking something similar. If I know that valve has equal percentage characteristic,...
Not a direct answer but there are two things you need to consider the valve trim can be Linear or...
CDM
Originally posted by car1615 on 6 November, 2009 - 7:15 am
Does anyone use CDM for their GTs with DLN?
New Replies:
The ECOMAX system tunes continuously. It will tune after an outage, or during normal operations. ...
New exhaust temp. setting of MS5001 GT
Originally posted by GTEGAT on 25 September, 2009 - 5:58 am
How to determine the new exhaust temperature setting of MS5001 GE Gas turbine, after changed of capital part to R or P/NT type.
New Replies:
The originator's question should be answered by the company providing the hardware and software to...
good question please what are exhaust spreads mean?...
Switching supply of house load
Posted by Mik on 17 November, 2009 - 1:43 pm
When to switch house load to the generated power?
from the Mechanical department...
Calculation process of FSNL of Mark-4
Originally posted by Mijan on 17 November, 2009 - 2:01 am
Need calculation process of FSNL of Mark-4 GT
New Replies:
Depending on the vintage of the Mark IV used on the turbine, it's not very scientific. How long...
You use the term "disconnect from the grid." If you mean that the 52G generator breaker...
Rewinding of Brushless Generator Rotor
Originally posted by Shamyl on 16 November, 2009 - 12:38 pm
Testing Procedure for a rotor which has been rewound!!
New Replies:
> What are the things that one needs to check? I can help you, please read this...
Topic: Communications systems and equipment.
Originally posted by Daniel Barrera on 13 November, 2009 - 9:26 am
I have a problem when I want to read the modbus of SHARK 100, because I can't read 32-bit IEEE floating point format in VIJEO DESIGNER 5.0.
New Replies:
Hi guys, If you cannot find a solution, I can recommend using a gateway. HMS has one that may...
> And, speaking of standards... I would sure love to see a date standard. What is 3/6/9? March...
There is an option for each device communications driver to change the double word order. If the FP...
from the EE department...
pf control
Originally posted by eurydice on 5 November, 2009 - 10:44 pm
AVR control of islanded systems
New Replies:
Thanks CSA and Blackstoneboy for the explanation.. I'll check the ratings of machines.....
Turbine Speed Variation in droop mode
Originally posted by Adeel Imtiaz on 16 November, 2009 - 6:33 am
We are facing speed variation in one of our turbine in DROOP mode. Variation is between 5088-5090.
New Replies:
CSA said: > More problems can be created where none existed by technicians performing...
When you operate two generators in parallel, with one in droop and one in isochronous mode, the...
It's likely the two are one. If your post is understood correctly, 701 is controlled by the...
Field breaker opened accidentally
Originally posted by anybody on 15 November, 2009 - 6:42 pm
generator field breaker opened accidentally
New Replies:
Thanks, Phil. I can always count on you to point out any errors in my replies. I realized my...
CSA... I agree with your admonition... tripping is necessary! However, I disagree with two of your...
the unit did trip opening generator main cb. operator asked the question and i was looking for a...
If ANYBODY's unit was on line producing 100 megawatts and the field breaker opened, accidentally or...
SPPA T3000 installation
Topic: PLCs and related questions.
Posted by NISHAR on 16 November, 2009 - 8:26 am
SPPA T 3000 installation
Turbine Supervisory Instruments
Originally posted by zionsiri on 25 November, 2008 - 11:46 am
Online information for TSI
New Replies:
Contact Mechanalysis India at www.mechanalysisindia.com or our Partner in UK Sensonic Instruments...
from the BB department...
F9 SLOW ROLL
Originally posted by BB on 12 November, 2009 - 4:27 am
SLOW ROLL issue
New Replies:
Hi all, On the name plate of 20TU1 and 20TU2, the max pressure rate is 3000 psi. when we checked...
I have similar case to share. But I believe my case is not so bad as compared to BB. One of my...
It does sound as if the "controls" portion of the torque converter is working properly....
Thanks for help, Really I don't know if the torque converter is working well. From the command...
from the Instrumentation department...
Fire Resistant /Flame Retardant Cables
Originally posted by Srinivas on 29 December, 2006 - 9:44 am
What type of cable can be used for Gas Detectors in Zone 0.
New Replies:
i understood what ever u said. MAY i know the exact difference between Fire resistance Low smoke...
Originally posted by James on 13 November, 2009 - 10:04 pm
Latched output on BN vibration monitors, series 3300
New Replies:
It will only latch the trip relay after the 3secs delay. And also the vibration value should have...
Posted by frankhardy on 14 November, 2009 - 1:34 pm
UPS having "high DC bus error on rectifier" error message. Need advice on connection to UPS from neutral point of vessel based power supply configuration
GE frame Generator Vibration Problem
Originally posted by _carlo_ on 23 June, 2009 - 4:03 am
GE frame Generator Vibration Problem and turbine trips
New Replies:
Ig... negative-sequence would show up as unbalanced stator currents! Thus far, none of the...
Often reason of vibration is a short circuit in a winding of a rotor I have a negative experience...
from the Newbies department...
Reactive Power, reactive load, voltage
Posted by blackstoneboy on 14 November, 2009 - 12:34 am
Got few questions in regards with Reactive Power, Reactive Load, voltage and power factor
Originally posted by Pirate on 13 November, 2009 - 6:48 am
Gas pipe before the gas nozzle is vibrates continually
New Replies:
Are you sure that the piping is properly supported? If the piping wasn't re-installed properly and...
Advertisement
