I have a couple of questions regarding the field installation of a Profibus DP network:
1) Are active terminators required at both the source and destination ends of each segment, or at one end only? If needed at both ends, why?
2) We need to make some outdoor tee (T) type junctions so that we can remove/isolate field equipment without breaking the bus. Are there any special technical requirements for this tee or can it be done using a simple junction box and ordinary terminals? If special T's are required, do you know of any standard equipment and why is this required?
3) Are there any maximum take-off distance requirements between the T and the field devices?
James Stokes
James Stokes
