H
S7-400 414-2DP
i would like to get a comment regarding my problem of profibus network down (the led indicator for both BUSF and INTF are on on the CPU). what could possibly cause the profibus network to go down suddenly then without touching/doing anything it would come back up again?
defective profibus connectors? defective cpu? i checked the cabling and it is ok, no grounding between the red and green and the ground wire.
when i check for short between the red and green wire of the profibus network, i remove the profibus connector from the PLC, remove the green and red wires from the connectors and test for shorting from there. while all other profibus connectors are connected to their respective slave units. i just use a digital tester to check the continuity. when i put the red probe to the profibus green wire and the black probe to the profibus red wire, i get a continuity. but when i probe with red probe to profibus red wire and black probe to the profibus green wire, there is no continuity. is this a normal condition for the network wiring?
