P
I wanted to ask about the turbine GE MS 9001E, after overhauling cooldown can not be done, when the torque converter (voith) did not participate dismantled (not experiencing overhaul). as additional information, 1, 2, 3 turbine bearings replaced new with appropriate clearance standard. If using with hydraulic jack from the compressor clutch to acc gear, turbine rotor can rotate but if using a torque converter (cooldown) only lasted about 5 minutes. Is it possible to set the angle of transmission fluid in a torque converter? Please advice
