Hi All,
I have a 37KW motor, speed around 1500 rpm, i want to do predictive maintenance by placing vibration sensor to detect bearing failure, looseness etc, is 4-20mA accelerometer can do that? the reason of choosing 4-20mA "static signal" is easier to directly connect it to my PLC unit, or is it useless to use 4-20mA vibration sensor in this case? please your advice and if you have a better solution to detect failures on such a motor.
Thank you very much
Thank you very much
