I understand that rules are rules, However I have never seen in many years of experience an inductive voltage problem with a 24 volt digital signal... For example thare are 10 1 hp 480vac motors with 10 photo electic sensors all in the same wireway all in seperate cables (non shieled). why would this be reason for a separation? If it were a 4 to 20ma signal sure...
My request is: Can anyone explain to me mathmatically or electrially that the inductance of a 3 conductor #10 cable at 460vac can cause or not cause a voltage spike suficient to trigger an AB PLC SLC 504 24vdc Digital input card at a distance of 30 feet? I would like to present the answer to the powers that be, however I am also a realist and don't think it will change matters... But I would like to know for sure....
