Our GTG PG 5371PA, is under uprate and MI.
Please tell Bump test procedure for it.
Regards and Thanks.
Regards and Thanks.
AshutoshMehndiratta,
This is Control.com. Occasionally we answer questions that are more mechanical in nature--because controls uses or controls mechanical devices (in many instances).
This is pretty much strictly a mechanical question.
Having said that, when I think of or am asked about a "bump test" in relation to an uprate and MI, I think of a rotor bump check (another name for the same thing--isn't the English language a wonderful thing.?.?.?!!!).
Sir, I do agree with you. Its the beauty of English language.
What I actually meant is, the start up procedure and precautions, testings that are to be carried out before machine is loaded to base load??
Kindly explain them???
Thanks and Regards
Ashutosh Mehndiratta
turbine gas frame 6B house load test | Power Generation | 2 | ||
Acopos 1045 test | Motion Control | 0 | ||
Finding Kp, Ki, and Kd Values from Bump Test | Process Control | 3 | ||
A | PID Control Bump Less Transfer | Process Control | 9 | |
S | DeltaV-Bump on OPS | Human Machine Interface - HMI | 1 |
