We have GE Frame -III machine which is equipped with gas turbostarter. The jaw clutch is getting disengaged at TNH of 39% speed.
We found that the angle of the teeth of jaw clutch was changed by friction and became wider.
-Is this problem the cause of disengagement?
-If the L14HA constant is increased to around 60%, what is the consequence, and will the problem be solved?
