Hi You should normally get those indications on OEM manuals ..Hi
if i want to conduct short cuircuit test in generators which protection for generator i should disable
thank you for your support
Again that will be very helpful for you to get Test protocol document from OEM as it is well written how to perform such TEST...Thank you
That Beckwith relay is pretty good and very complete for your Generator Unit protection.Thae protection relay is BECKWITH M3425A model,Prime mover Hydlrulic starter ,,Generator type brushless with PMG
no Prime mover it is Gas turbineturbine
Gas turbine can also be called "prime mover " dear friend!no Prime mover it is Gas turbine
Thank you for you comments, one of my friend thinks prime mover is steam i just tolld him its Gas turbineGas turbine can also be called "prime mover " dear friend!
Amie...
Short-Circuit-Test of Generator reduces its output voltage to zero, thus all trip or supervisory functions related to voltage (at least 10) provided by the BECKWITH Relay go to zero for the duration of the test.
Phil
by Bob Odhiambo
by Bob Odhiambo
