Hi All,
I was hoping to get some advice on how I might communicate with an EATON IQ 100 power meter. The meter has an RS 485 port and Modbus-RTU Protocol. The datasheet is attached if it helps. The meter is located in a generator room, unfortunately, there is no wifi or internet in that room. However, there is a wired R485 link from the meter to another part of the building where an internet connection is available. Until now the meter has simply been connected via the Modbus port to a local laptop in the generator room. Data is stored on the laptop and periodically downloaded. I would like to remove the need to have a laptop on site and simply have the meter push data to the cloud through an internet connection. The data can then be accessed remotely by the client. Ideally, it would log the meter registers and save data to a.csv file. I think this should be possible and have found the following device (http://www.iccdesigns.com/millennium-series/10-eth-1000.html). No idea if this would be compatible or useable with the EATON meter.
Any ideas or advice would be appreciated.
