I was wondering if anyone has experience using DIN Rail Terminal Blocks for MODBUS RTU. I have a single cabinet which contains 4 different MODBUS RTU Slave devices over RS485 as well as the Master. Will it work ok if I chained together a few Din Rail terminal blocks to connect all my devices to the Master. I understand that this may not be a great practice considering losing the twist, but is it likely to cause issues considering I am only using a few feet of cable overall? I am just looking to simplify the cabling as much as possible and make it easy to add and remove devices as needed. Any other cabling suggestions to achieve this would also be appreciated.
Thanks for you Time!
