I am currently installing 2 systems of enveloping machines in Canada.The systems were designed and built in Switzerland where the frequency of the 3 ph powere is 50 hz. I am finding that the screens that are scsi controlled touch screens, are glitching (horizontal lines) when used on a 60 hz power system (canada). The screens are controlled thru an industrial PC with a standard 100-240 vac 50-60 hz PSU. I also have a problem with the software crashing out into the dos prompt for no apparent reason. Does the SCSI screen have any components that would be specific to it running on a 50Hz system, or is all the timing taken from an internal time base on the SCSI interface card, any ideas????????
I am a lone Englishman in a sea of Canadians wanting my head on a platter......
