I just recently replaced the cx1010-0010 CPU module with the power supply unit. After the replacement the X0 & X1 inputs of the EM7004 IO was not responding. So I changed the EM7004 module also thinking it had failed. Still the digital inputs and not taken into the PLC. It is physically coming till the IO ports and LED all lighted up but when I check through the twincat system manager all inputs show "0". I want to know whether do I need to do any configuration for the digital inputs. All digital outputs are working fine in both instances. Please help me out in this issue. Thanks in advance.
