P
We have 6B gas turbine with Supplementary firing (OIL) in service less oil flow gives more smoke at HRSH Exhaust than expected. Gas turbine kept on IGV Temp. control ON with IGV 56 degree Opening with exhaust 540 deg c & Load 22 MW. Liquid fuel HSD Standard combustor. Ambient temperature 25 deg c.
Need suggestion for the better operation to reduce the black smoke at HRSG Exhaust. In HRSG 10 Burners running 5 Each side. Augmentary Air fan IGV 100% open.
