I need to capture data at a relatively high rate (1 ms or less) in a ControlLogix motion control application. I've found that, for some unknown reason, Rockwell Software has not seen fit to develop the software to do this. There isn't even a white paper or application note available from RS. I've been told that I have to develop my own application with a routine in the controller to gather the data in an array in controller memory, then use RSLinx to pull the data into a spreadsheet. It appears that this will have a limit of about a 3 ms update time, which is much slower than I had hoped for.
Has anyone out there dealt with this situation before? Any advice or guidance? It's probably too much to hope for, but is there a third party software solution that anyone would be aware of to achieve my desired goal?
Thanks,
Dave Osborn
Butech, Inc.
Thanks,
Dave Osborn
Butech, Inc.
