Hi:
Has anyone run into a problem using a 1784-PCC card on a laptop with one PCMCIA slot? The card installs fine but when I try to configure the driver in Linx, my computer locks up. Even running Rockwell's Pcc_test program locks the computer up on the last step (interrupt test). Rockwell says they are working on a solution but I don't know how long that will take. Is there anything I can do to work around this problem (without going to a different protocal) until Rockwell gets a solution? Thanks,
Corey
Corey
