We got an ABB make AC800F DCS. I have some problems with this. The I/O Processor (CI830F) doesn't boot sometimes & all the subsequent I/O Modules attached to this I/O processor doesn't go into run mode.
But once I switch the entire DCS off & again switch them ON the I/O Processor does go into Run mode. Totally I have 5 (CI830F)I/O Processors connected to the main controller.Sometimes all the 5 go into run mode & sometimes 1 or 2 of them fail.
We did set all the paramters (i.e baud rate etc ) as per ABB specifications.
One more problem is setting the controller date & time. As per ABB , Freelance 2000 Version 7.1 should support setting of date & time via ethernet port , but we are not able to do this.
If any one has undergone any such problems & have been able to come up with some remedy then plz do help me.Any other advices are also welcome.
