ABB Frellance Talking to Modicon Quantum PLC Via Modbus TCP/IP
L
Lakshmikanth
I have a network of 6 Modicon Quantum PLCs and a SCADA system which is running on a Modbus TCP/IP network. Now I need to replace the SCADA system with ABB Freelance (Digivis) Software. How do i do the communication set up? I am not suppose to establish a new network. I need to plug in the ABB system in to the existing Modbus TCP/IP network. The existing SCADA system works on its own built in OPC server. Can I use any Third party OPC server or is their any other easy method? Anyone please help me.
Thanks n Regards,
Lakshmikanth
W
Wassim Daoud
You may use a third party OPC Server for your Modicon PLC ...
http://www.matrikonopc.com/opc-drivers/opc-modbus/base-driver-details.aspx
I am not sure what protocol are you choosing for the ABB FreeLance... but you can create your own OPC Server without programming by using this toolkit:
http://www.matrikonopc.com/opc-drivers/815/index.aspx
Then you can connect them together with OPC Data Manager... to get the data going bidirectional between the two systems:
http://www.matrikonopc.com/products/opc-data-management/opc-data-manager.aspx
Hope this is helpful
Let me know if you have any questions
Wassim Daoud
Global Solutions Architect
www.MatrikonOPC.com
