I am needing to run a 50hp AC motor on 128v DC/ 1500 amphour batteries like a large forklift control.
I am an engineer working on a battery operated machine. It currently uses a 50 hp DC motor running through a gearbox and seminco controls. The machine has drive shafts linking the motor to the front and rear John Deere axles. Top speed is regulated at 6 mph. The machine starts and stops frequently and carries a load of up to 30,000 lbs. I need to convert this machine to an AC motor mounted directly to each front and rear axle to eliminate the drive shafts and gear box. Can anyone give me direction on what is the "state of the art" vendor for motor controls in this HP range? Battery power and motor life is very important, but the cost of setting up the machines to do the job properly is not a factor.
