Our units have two access plates, about 10 inch by 4 inch, located at approx the 5 and 7 o'clock position on the inlet plenum. If you enter the inlet plenum the LVDT's can be changed thru them. These plates are welded in place so will need to be cut first. It still quite a task but do-able.
