H
First off, i'm no electronics wizz. I'm building from plans located here:
http://dmgaming.com/timer/timerv2-schematic.htm
I've wired it all up but when i tested it the output that the computer received according to the software was questionable to say the least.
The default value of the sensor inputs, that is, without being connected to anything, was around 1.7v, but constantly fluctuated between 1.65v and 1.75v. When the sensor inputs are connected to ground, the output reads 0.00v, and similarly when they are connected to 5.00v it reads 5.00v. What's odd is that regardless of how much resistance is put in between the sensor input and the 5.00v it still reads 5.00v. Also, when you touch one of the sensor inputs with your bare fingers, all of the readings go crazy! whats goin on here guys?
Thanks a lot for any and all reply's, very cool community!
H
H
