adding more points to user define screen on MKV system
O
obed opoku
i want to add more data point names on MKV. i know how to add them, but the problem is obtaining the actual data point names. for example i want add maximum bearing metal temp, gen cold/hot gas temps and max gen stator temps. i see them displayed on the screen but i can't find their tag name to add to my user defined screen.
You didn't tell us if the operator interface is an <I> or a GE Mark V HMI running MS-Windows and CIMPLICITY.
Do you know how to use the Dynamic Rung Display and/or do you have a printed copy of the CSP and the CSP Cross-Reference?
If you also told us what Frame size machine you are working on and what kind of generator (air-cooled; water-air cooled; or hydrogen-cooled) someone who has a similar unit may be able to help you with signal names close to the ones in use in your machine. Not all machines use the same signal names.
