I am adding two nodes to the Mark V Arcnet network, so that the balance of plant server can access Mark V data for monitoring/control/historian. I plan to remove the terminating resistors from each of the existing GE HMI nodes, and add a length of coax and place the terminating resistor at the tee on the new Arcnet card.
What do I use for the Arcnet card (PCI20U-CXB) driver? Balance of Plant is running Windows 2008 R2, and the Arcnet card will communicate with an OPC server.
