We are using two AC450 controllers for our 2 Nos. 18MW Powerplant. And AdvaCommand 1.7 as MMI. Both the units are controlled by seperate dedicated controllers sitting on the same MB300 network. We are facing problem that whenever fault is generated in unit one object it is also affecting the unit II object. I mean to say if some fault (say Local stop) is coming in unit 1st MMCX38, it is also tripping the drive of unit II which is having the address MMCX38 in the other controller. Be informed that there is no any physical connection between these two objects. We have already done the object reference maintainence (Retranslation) but the problem is still persisting.
Any firm solution will be highly appreciated.
Dosani M.
Dosani M.
