Is there any relationship between air mass flow and igv angle in gas turbine (Siemens v94.2)? and what is the value of air flow at minimum igv angle (fully closed)?
M | Repeated motor winding failure of IngersollRand Screw Air Compressors 75 kW | Electrical Engineering | 7 | |
A | Air Mass Flow Rate of the Gas Turbine Compressor | Power Generation | 1 | |
H | GT Intake Air Mass Flow Measurement | Instrumentation & Measurement | 0 | |
B | Inlet mass flow rate of air V/s CPD | Process Control | 15 | |
K | Mass flow air balancing | Process Control | 0 |
