Can anyone recommend a source for a heat exchanger with the following spec's... Need one ASAP.
Heat Exchanger - Air to Oil type, 19,500 Btu/Hr heat dissipation from 3 GPM (ISO 32 Fluid) with and ambinet air of 120 degrees F maximum and a maximum oil outlet temperature of the 140 degrees F. The electric motor for the fan shall comply with IEEE 841, Electrical service is 460 Volt-3phase-60 Hertz.
Thanks,
C. Corzine
Thanks,
C. Corzine
