ALARM MESSAGE BUILDER PROBLEM
  • Thread starter Mihir Ramkrishna
  • Start date
Mihir Ramkrishna
In the OPTION_BUILDER_MENU there is MIF PACKGE MENU in which there is Report Builder menu wherein I have created a new file SAMPLE1 and the
AEV configuration is as follows:
Title: ALARM/EVENT REPORT
Start time: YESTERDAY
Stop time: NOW
Directorys: 0-7
Stations: 1-64
Areas: 0-8
Prioritys: 0-31
Tags: ALL
Operator IDs: ALL
Console IDs: ALL
Sort Criteria: Time
Search String:
Output file: stdout
After doing the above, in MIF_PACKAGE_MENU, I had gone to Schedule builder where in I have created a new Schedule with the following:
Schedule name: SAMPLE1
Exec Time
Month: 1 (not highlighted) (1-12)
Day: 1 (1-31)
Hour: 7
Min: 00
Week: 0(not highlighted) (0)
Status:
Enable
Exec command:
miafev ^Öf SAMPLE1 | lp ^Öd prt ^ÖTeuc ^Ö0 nobanner
Then in ICS, I have in MIF package, Schedule where I have seen
Name Description last execution Next Execution Status
SAMPLE1 time when execution time in scheduler STOPPED
was tried & next days date
after executing it, it gives message RUN REQ RUNNING & STOPPED. Nothing happens on the printer. WHY?
Will the SAMPLE1 file reside in the ICS? If yes then where is it located? Can I take a print of it when desired by using UNIX command? If
yes what is that command?
