K
Dear All,
I would be grateful if someone can help me with the following issue:
My site uses a MarkVIe with Cimplicity Version 6.1.
We have installed an alarm module which needs a just dry contact to sound so we decided to use the L30ALM signal to drive it through a discrete I/O card contact.
The problem is that we are trying to use the SILENCE button on the Alarm page of the HMI to make the signal HORN_SIL_PCB change to TRUE in order to use it to drive a push button handler in TOOLBOXST.
However, whenever the Silence button is pressed on the HMI,the HORN_SILENCE_PCB signal does not change state but continue to remain false.
What are your suggestions please?
