T
Dear Sir,
in one of the major shutdowns of GE frame 6 turbine, it was found that the exhaust casing has a major crack that required a replacement. The new exhaust casing was brought & fixed to the turbine casing. however the bearing no. 2 that the hot bearing located in frame 6 exhaust casing requires an an axial & radial alignment. Kindly guide me how to do it..
